Eec-iv
Eec-iv
If still stock, it should have EEC-IV. With EEC-IV, the distributor should have an ignition module at the base with a few wires coming out of it and no vacuum advance. Along with this, you'd have an electronic feedback carburetor.
If it was the non-computer controlled Duraspark system, it would have vacuum advance with the ignition module on the inner fender.
Eec-iv
If it is the original engine and your sure no one has changed the ignition system. Look on the emission control/vacuum diagram in the middle of the radiator support brace and it should have ECC-IV printed somewhere on it. If my memory is correct it is on the right lower side of the diagram as you face the front of the truck.
RussA
RussA
84ford460
09-02-2003 08:58 PM
