Eec-iv
Old Sep 16, 2003 | 04:16 PM
Oscar Meier's Avatar
Oscar Meier
Eec-iv
How can I tell if my '86 4x2 300 I6 has a EEC-IV ignition system?
I am checking into new cap, rotor & wires and accel has a kit for 84-86 4.9 L with carb & EEC-IV Ign's.
Need to know how to check for EEC-IV type.
Thanks for Info.
Old Sep 16, 2003 | 05:15 PM
brown 4x4's Avatar
brown 4x4
Eec-iv
If still stock, it should have EEC-IV. With EEC-IV, the distributor should have an ignition module at the base with a few wires coming out of it and no vacuum advance. Along with this, you'd have an electronic feedback carburetor.
If it was the non-computer controlled Duraspark system, it would have vacuum advance with the ignition module on the inner fender.
Old Sep 16, 2003 | 07:31 PM
rander101's Avatar
rander101
Eec-iv
If it is the original engine and your sure no one has changed the ignition system. Look on the emission control/vacuum diagram in the middle of the radiator support brace and it should have ECC-IV printed somewhere on it. If my memory is correct it is on the right lower side of the diagram as you face the front of the truck.
RussA
Old Sep 16, 2003 | 10:01 PM
Oscar Meier
Eec-iv
This leads me to another question - If I were to install one of the Offy 4 bbl manifolds and 4 bbl carb, and I do have the EEC-IV system, then would I need to change to the Duraspark Ignition?(or some other non-computer controlled ignition)
Thanks for the help.
eagle275
Computer Chips & Tuners
22
Apr 25, 2010 09:41 PM
mike L
Jan 23, 2010 10:08 AM
switzee
Bronco II
Jul 14, 2005 12:34 AM
84ford460
Sep 2, 2003 08:58 PM
stone
Jan 25, 2001 12:36 AM
