manual transmissions
Ford 3.03 3 speed 80-86
Borg Warner T18 80-90
Borg Warner T19 83-87 Diesel and 460 only
New Process 435 80-87
4 speed manual overdrive 80-84
TOD 4 speed manual overdrive 84-87
SROD 4 speed manual overdrive 80-84
M50D-R2 5 speed manual overdrive 80-90
ZF S5-42 5 speed manual overdrive 88-90 *F150 and bronco in 4X4 only, and all larger F series
Ford F-series stick shift gear ratio's
Transmission======1st==2nd==3rd=4th==5th==6th
ZFS6=650========5.79=3.30=2.10=1.30=1.00=0.72
ZFS5=47=========5.72=2.94=1.61=1.00=0.76
T19=========****4.02=3.03=1.79=1.00
T18=non syncro 1st==6.32=3.09=1.69=1.00
NP435=no sync 1st==6.69=3.34=1.79=1.00
ZF S5-47 from a 97 down F250/350 has a removable bell housing
****T19 has an optional 1st: ratio's of 6.32 and 5.11
on
1 Post
Whatever tranny is in my (former) '84 must be a good one as it has about 200,000 miles on it and still works great. Had one fluid change back at about 95,000 miles where we drained it and refilled it with 10w40 motor oil which has been in there since. THe 10w40 made it much easier to shift on cold mornings. It was a 4speed with OD that had ratios: 3.01, 1.78, 1.00, and 0.71 with a 2.47 rear end. Never towed with it though.
