What is the spreadbore carb on 460's?
09-12-2003, 11:02 PM
on
I did a little searching on this fourm to get the information for myself but I wanted to ask anyway; what is the model of the spreadbore carburetor found on 460's?
I bought a 4bb intake for a Cleveland with the small, 2v type ports and it has a spreadbore throttle plate configuration.
The model number I found by searching is 4180 and I assume that this is an Autolite carb. Are there any other models of Autolite carbs with the same spreadbore pattern?
09-13-2003, 01:38 AM
4300 Motorcraft, spreadbore.
Don't know about any Autolite spreadbores.
In 70 and 71 an actual Rochester Quadrajet spreadbore, 715CFM, was made for the 429 CJ's and Police Interceptors.
09-13-2003, 03:40 AM
on
Autolite carbs were renamed to Motorcraft sometime around 1970.
4180 sounds like a Holley number.
09-14-2003, 01:47 AM
Yes the 4180 was the Holley/Motorcraft 4bbl, but it is not a spreadbore.
It is the standard Holley squarebore.
09-14-2003, 06:21 PM
Motorcraft 4350 is also a 460 spreadbore application
09-16-2003, 12:31 AM
on
The Motorcraft carbs are JUNK.
I used a adapter plate and use a Holley carb now.
09-16-2003, 10:47 PM
on
Uhhhh. Holley makes Motorcraft carbs, don't they?
09-17-2003, 12:29 AM
No.
09-17-2003, 01:10 AM
on
Ok, my bad. I thought the Holley 4010 and 4011 were Motorcraft carbs.
09-17-2003, 05:18 AM
on
When Ford ditched the 43xx sometime in the early 80's, they started using Holleys instead. These Holleys come with a Motorcraft tag.
09-17-2003, 10:56 PM
The Holley / Motorcraft 4180 CFM is somewhat similar to a 4160 Holley 600 CFM.
But from what I have read, the 4180 is not a performance carburetor and can not be made into one.
roxndirt64
19
09-01-2022 10:43 AM
AK FORD GUY
51
11-30-2013 10:19 PM
db9397
11-10-2013 02:10 PM
68cabby
06-17-2012 09:02 PM
