Hub caps
Old 09-12-2003, 10:07 PM
elstx's Avatar
elstx
elstx is offline
Hub caps
Anyone have a photo of the original hub cabs for a 68 F250?
Old 09-13-2003, 12:44 AM
NM5K's Avatar
NM5K
NM5K is offline
Hub caps
I have a brouchure of the 67 F-250 caps at a distance. The picture is of a F-250 camper special. I'm fairly sure the 68 caps are the same. Or very close anyway..Being I don't think I have your real E-mail on this site, I'm not sure how to send it to you. I don't think I can post it here. The caps are silver- chrome looking, and naturally pop on the inside part of the wheel. "Often split rims in that day, as my 68 F-250 did." The caps for the f-250's are a good bit deeper than the caps you see on a 1/2 ton truck, being they have to be able to clear the hubs that stick out on the 3/4 ton truck. I'd like to find a set of caps for mine. I don't have any of the originals that came on mine. I just got rid of my split rims a couple of months ago. I hated tube tires...Not fond of split rims either. Many places won't touch them these days. They can take your head off if you don't know how to mount them correctly and they fly apart. I also switched from the old 16 inch bias truck tires to radials. MK
Old 09-13-2003, 12:48 AM
elstx's Avatar
elstx
elstx is offline
Old 09-13-2003, 09:41 AM
DuckRyder's Avatar
DuckRyder
DuckRyder is offline
Old 09-13-2003, 08:06 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Hub caps
The hubcaps were used until at least 76. I pick them up when ever I find them. Some are painted argent with black trim and others are chrome or stainless. The F-350s used the same thing only those are deeper. The econolines also used them. The chrome ones are pretty hard to find. I have a set on my 72 that I got off a guy that bought white spoke wheels to replace his split rims. My 68 has the painted ones but I have scavenged them here and there as it came with only 2 and they were caved in. I also have 3 of the F-350 chrome ones that I got at a swap meet.
Old 09-14-2003, 06:31 PM
tripticker's Avatar
tripticker
tripticker is offline
Hub caps
DuckRyder,
Do you have the same link/info for hubcaps for the '67 F-100?
Thanks.
Old 09-14-2003, 06:34 PM
DuckRyder's Avatar
DuckRyder
Hub caps
Originally posted by tripticker
DuckRyder,
Thanks.
http://www.bumpsides.com/67lit/index.html
The main site is:
And is owned by a member here.
Old 09-14-2003, 06:35 PM
tripticker's Avatar
tripticker
Hub caps
Thanks DuckRyder.
Old 12-12-2003, 02:20 PM
oem78's Avatar
oem78
oem78 is offline
I'v got a sales brochure for 1978 pickups and the F250 and F350 have these same hub caps, chrome with black painted slots and crown ford emblem in the center. In 1979 they changed the look of the hub caps. My 1978 4x4 has a set on them, and there is a picture in the gallery of them. oem78
Old 12-15-2003, 06:15 PM
willowbilly3
The F-350 hubcaps are deeper than the F-250 ones.
Old 12-15-2003, 11:18 PM
oem78's Avatar
oem78
oem78 is offline
Why would they need to be deeper ? The F350 has a heavier set of leaf springs and front coils, The axles are the same I believe, and the tires are 16.5, but the hub caps are the same I believe.
Old 12-16-2003, 12:45 AM
willowbilly3
I am not sure why unless the Dana 70 axles stick out further. I have three of the deeper F-350 hubcaps hanging on the wall in my shed. I also ran one on my 72 for a couple years until I found a replacement, but those were the painted ones. Even the later ones that came out around 78 have deeper ones for the F-350.
