What are the "Build Sheet" Codes?
Old 09-07-2001, 07:23 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
Old 10-10-2001, 10:22 PM
2nd1's Avatar
2nd1
2nd1 is offline
I just bought a used 1990 F250 4X4 and the build sheet was still under the seat. Yes it was a bit tattered and torn with rust stripes going through it from the seat wires, but nevertheless it was there. I would really like to know what my truck came from the factory with. Does any one know where I can get any info on this?
Thanks!
Old 10-10-2001, 11:03 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Post the VIN & I can tell you where it was built .
Old 10-30-2001, 05:05 PM
beratte's Avatar
beratte
beratte is offline
I sent an email to Ford Customer service to see if I could get a copy of the window sticker for my truck and they had me send them the vin# and then told me what dealer it originally came from. They said I would have to contact the original dealer to get a copy of it. Haven't done it yet though. www.qualitycareservice.com Good luck, Ben
Old 10-30-2001, 08:43 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bdf653c63e13c28.gif
Post everything from the data plate.
I can tell you lots about the Data plate information.
Let's just hope it's the original door/data plate !
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Old 10-30-2001, 08:52 PM
2nd1's Avatar
2nd1
2nd1 is offline
https://www.ford-trucks.com/dcforum/User_files/2nd1/sticker.jpg
Well I finally got my truck back and the VIN is:
2FTHF26H5LCA17495.
If anyone can provide more info as to what the codes in this sticker are I'd really appreciate it!
Old 10-30-2001, 09:24 PM
cbremer's Avatar
cbremer
cbremer is offline
1FT: Ford Truck, USA
H: Hydraulic brake, 8501-9000lb weight class
F26: F-series F-250 Regular cab
H: 5.8L (351ci) gasoline Ford engine
5: "check digit"
L: 1990 Model year
C: Ontario Truck Assembly Plant
A17495: serial number
WB: wheelbase 133"
Type GVW F268: 8600 lb GVWR, 133" wheelbase 4WD F250
Body BJ4: Knit vinyl bench seat-granite color/styleside pickup
Trans E: Automatic-E4OD tranny
Axle C5: 4.10 ratio axle with 6250 lb capacity
Tape: trim tape (you have no trim tape... its usually on 2-tone paint jobs)
Springs 493F: letters/numbers correspond to Ford part numbers for the springs
Exterior paint code YW: Smoke metallic (2-tone has 2, 2 letter codes)
As Dennis said, theres a lot of info on these tags!
Chuck
Old 10-30-2001, 10:00 PM
2nd1's Avatar
2nd1
2nd1 is offline
Hey thanks Chuck! That's sure a lot more than I had. By the way do you know if the rear axle is Ford or Dana?
Thanks,
Clif
Old 10-30-2001, 10:23 PM
cbremer's Avatar
cbremer
cbremer is offline
Looks like your axle is a 10.25" Sterling (Ford) axle in back, and being that you have a 4WD, your front is the Dana 44 IFS-HD axle. This, of course, assumes that nobody has swapped axles before you got a hold of that truck!
Glad to help!
Chuck
Old 10-31-2001, 06:57 PM
lt's Avatar
lt
lt is offline
I found mine under the front seat, between the spring and the foam - passenger side. But then my truck was made in Canada.
Hope this helps.....
Larry
mthunter@peoplepc.com
1990 F250 XLT Lariat 4X4 351 E4od - 124K miles
Old 11-14-2001, 05:57 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
I tried that quality care website.I wrote to the address to find out who/where the original selling Ford dealership was of my '90 Bronco.I included all of the information-including my e-mail address,but they never contacted me.Good thing I didn't take their survey.....
Old 11-14-2001, 07:18 PM
beratte's Avatar
beratte
beratte is offline
I emailed them and they sent me a message back the next day. They've been pretty helpful to me. Maybe you should try and email them again.
Old 11-14-2001, 10:10 PM
2nd1's Avatar
2nd1
2nd1 is offline
What email address did you use?
Thanks,
Clif
Old 11-14-2001, 11:14 PM
beratte's Avatar
beratte
beratte is offline
Go to: https://www.ownerconnection.com/FormsLoginSSL.asp?Make=Unbranded&Model=default&L=4 9&N=840 and register if you have not and then go to contact us at the top right of the screen. You'll then go to a new screen and go to the bottom and click on email. That will take you to a new screen and it's self explanitory from there.
Old 11-15-2001, 05:38 AM
2nd1's Avatar
2nd1
2nd1 is offline
Thank you, I'll see what happens.
kbf1961
10-17-2015 10:05 PM
tlcsr66
05-14-2014 04:08 PM
1972RedNeck
05-30-2012 11:33 PM
FordMudder514
Bronco II
08-07-2003 06:16 PM
flatbranch
1997 - 2003 F150
06-02-2001 10:55 AM
Quick Reply: What are the "Build Sheet" Codes?
