Aerostar Ford Aerostar
Check Engine Light Function
Old 09-01-2003, 11:18 PM
Kerry's Avatar
Kerry
Kerry is offline
Does the check engine light only come on when you have a sensor failure or sensor out of range? I would think that any sensor out of range should cause the check engine light to come on. However, in reading this forum and talking to others it seems that many of you have had sensor failures but no check engine light. As a part of maintenance should a person periodically check for trouble codes even when the light is not on? Or, if the light is off does that mean all sensors are functioning within their normal range??
Thanks for your input.
Old 09-02-2003, 11:57 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
My understanding is that the computer only knows a sensor is bad if it fails outside of the expected range for that sensor. So, even though the value is considered valid by the computer, it still could be wrong for the given condition. Also, I don't think the computer has the ability to check the response rate of a sensor. For example, O2 sensors tend to get "lazy" (sluggish) rather than just fail. Changing a sluggish O2 sensor results in better performance, even though the computer didn't flag it. For older computers (OBD I), if you don't get a light, then you won't get a trouble code. I think OBD II systems have the ability to store non-latching fault codes for a certain number of start cycles. The only sure way that I know of to detect a bad sensor that still reports a valid value is to monitor it real time. Some of the fancier readers will let you do this. The only problem is that you would need to know what value the sensor should give for a certain condition (i.e., for an O2 sensor reading of X volts, and air MAF reading of Y volts, the injector pulse width should be Z msec). Or, I suppose you could look to see if the value changes when conditions change.
gamaliel
01-07-2013 08:33 AM
BadDogKuzz
04-28-2011 07:14 PM
mohrds
12-30-2007 10:04 AM
Mhzjunkie
1983 - 2012 Ranger & B-Series
06-12-2006 10:58 PM
ztuck
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
04-04-2006 11:07 AM
Quick Reply: Check Engine Light Function
