97 F250
Old 03-30-2017, 10:46 AM
Broberts's Avatar
Broberts
Broberts is offline
97 F250
Hey guys,
I have a 97 f250hd, 8800gvw, with a 5.8l gas, auto trans. VIN 1FTHX26H7VEA48029
Yesterday the trans started acting up. Would shift from first to second fine and then shift no further. Speedo quit working when this happened and ABS light comes and goes. 45 seconds later, after slowing down, the trans shifted fine and speedo started working again. Would this be the VSS? All fuses are good.
Also, i recently put a flat bed on the truck with after market tail/brake lights. However, the oem plug that feeds the back lights has 8 wires coming out of it and it has been cut off. Wire colors are orange with blue tracer, black with purple tracer, white with pink tracer, white, green, black, brown, and green with orange tracer. Could not locate a wiring harness with an 8 wire plug from salvage yard. They only have 5 wire. I have hard wired the lights using 5 of these wires but with the key in the on position, truck not running and headlights off, the tail lights are lit up. No idea what the other 3 wires are for. Also, a few days ago, was driving the truck and lost the instrument panel lights and side marker lights. All other lights are working. Any ideas?
Old 03-30-2017, 12:59 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Are the flatbed lights LED's? They can cause a lot of problems. If not, put in only a motorcraft VSS and see if that helps. By the way, this is the diesel forum but welcome anyway!
Old 03-30-2017, 02:26 PM
madpogue's Avatar
madpogue
madpogue is offline
Does the odometer display a number? Or is it blank?
Old 03-30-2017, 02:55 PM
Broberts's Avatar
Broberts
Broberts is offline
Yes. They are LED's. And sorry about posting in the diesel forum. Had a heck of time trying to navigate through this site.
Old 03-30-2017, 02:56 PM
Broberts's Avatar
Broberts
Broberts is offline
The odometer is old style and when the trans acts up the odometer sits on 0.
fordka
09-04-2012 09:22 PM
gravydude
10-29-2008 09:15 AM
stevegold1958
06-02-2007 10:00 AM
morganburger
08-25-2003 06:02 PM
logan_85
Electrical Systems/Wiring
07-17-2001 10:30 AM
Quick Reply: 97 F250
