holley air mixture screw adjustment
Hi Everyone. I'm new here and could use your expertise.
I have a 1986 class C motorhome with a 460.
I rebuilt the carburetor and put it back on the engine.
Carb # E5HE-9510-ED Holley
It's got 2 air mixture screws in the front of the base plate under the Primary Metering Body. Because of the location of the distributor and vaccum hoses that connect on the block I can't get to one of the mixture screws, let alone see it or adjust it.
I am wondering, if I took the Primary Metering Body off of another carb that has air mixture screws on the side of the metering body and adjusted the air mixture with them and just closed the ones on the front of the base if that would work?
If it would work does anyone know what model carburetor I would have to get one off of? Does it have to be from a carb off of a 460?
Your help is much appreciated.
Thank you
Thank you
Thanks fuzzybob.
I may have to do that. I just looked at it again and it seems to be a tree with about a half inch thread that screws into the manifold, with about 4 vac lines going to it.
If I pull that and plug the hole in the manifold would that work?
It doesn't need any of those vac lines for adjust the mixture screws does it?
Anyone else?
Thanks for the help
Anyone else?
Thanks for the help
Thanks fuzzybob for the help.
you are right, I just talked to holley and the metering bodies won't interchange.
So I'm headed out to start taking off the vac lines and go from there.
Thanks again.
I poste another thank you just before this one but I think I sent it somewhere else.
Sorry to anyone it goofs up.
Thanks again.
dan66tampa
19
03-13-2005 06:46 PM
Stingray42
07-29-2003 02:07 PM
