Shift selector locked
2001 E-350 but post here for better response. Shifter handle is locked in park with key in both off and run position. Can only get it out of park with the key in the position between off and run.
Unbolted the ignition switch and shifter would move. Found that it is the action of the ignition switch that makes the shift selector lock up. Seems like the problem is caused by the shift selector lock-out solenoid as the problem comes back when the switch is operated manually hanging from its wires.
Bad ignition switch or is there any other things that can make the solenoid lock the selector when not supposed to?
E-series aren't my area of expertise, but they're generally really close to the F-series.
Did you have the speed control recall (05S28) done a few years back? On this electrical configuration, an inoperative shift lock release or no brake lights due to a blown fuse was an early precursor to bigger problems (including fire) due to a leaking switch on the master cylinder.
