Brake Bleed
Old 03-25-2017, 04:18 PM
Chevmn56's Avatar
Chevmn56
Chevmn56 is offline
Brake Bleed
Hello all, just replaced all seals, hubs, rotors,calipers and lines on the front and rear axles. i am curious if there is a correct way to bleed the lines.....everyone has an opinion but what is the right way to bleed these they are 4 wheel ABS.....there is talk about a ABS special bleed through the ecu......i would just like to know what is the right way.
Thanks Pat
Old 03-25-2017, 04:29 PM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Old 03-25-2017, 11:07 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
I bleed truck in signature just like all older vehicles clear back to the fifties models.
Old 03-25-2017, 11:30 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Recommend finding a copy of the shop manual and study it. There's always little gotchas when it comes to brakes, betcha ABS just complicates things. Maybe not...but I'd want to at least read through the official procedure and decide for myself, idea being to avoid a marathon bleed session. I dislike bleeding brakes, once is enough at any given time.
Old 03-26-2017, 12:02 AM
IDI-Charlie's Avatar
IDI-Charlie
IDI-Charlie is offline
I've always bled furthest to closest from master, just doing it by the tried and true pedal pumping. If after bleeding you find you still have air, it is possible some got trapped in the ABS unit. If that happens you can go on a dirt road and - after ensuring nobody is around and it is safe to do so - hit the brakes hard to activate the ABS module. The other option is if you know a shop well most higher end scanners can actuate it.
Old 03-26-2017, 12:04 AM
JoeF250's Avatar
JoeF250
JoeF250 is offline
Speed bleeders, vacuum bleeders and pressure bleeders are all really nice; but not necessary. As far as I know there's nothing to worry about with the ECU. If you don't have any fancy tools the two person pump and open bleeder valve method will work just fine. But if have a wife that you choose to use as your assistant; she might get huffy about missing her HGTV shows while she's doing you the greatest favor ever.
Start from the wheel furthest from the Master cylinder and work your way towards it. Back passenger, back driver, front passenger, front driver; like any other car. This is also a great time to flush out the system. Cycle a pint or two through there to get all the water out, and you'll enjoy some really great peddle feel and reduce fade.
Old 03-26-2017, 12:15 AM
RepoTech's Avatar
RepoTech
RepoTech is offline
Gravity bleed
You didn't touch the master? Gravity bleed. Open all the bleeder screws and keep the reservoir full. monitor for about 30 minutes or until they all start flowing.
Then close them. I almost forgot. If you want to do it professionally then: 1) Put some old junk mail under the drips and spray off the residue with brake parts cleaner. 2) Flip over a bottle of brake fluid, upside down, in the reservoir without spilling, this is the tricky part. Imagine how a pets automatic water bowl/dispenser works.
Or if you want you could crack open a/the bleeder(s), connect a vacuum line type hose onto the screw and the other end into a partially filled with brake fluid container with the bottom of that hose submerged in the clean fluid and pump the brake pedal until you have someone see no more bubbles in that fluid. It will fill up some. Keep the reservoir full.
Old 03-26-2017, 01:11 PM
Chevmn56's Avatar
Chevmn56
Chevmn56 is offline
Have not done anything with the master cylinder yet....its in the mail lol........thanks for the info i as well use the wife and the down up method.....makes sense on the ABS ill do the dirt road thing tonight on the way home......the real reason i posted was in doing a search on this subject i found a few posts where people did their bleeding with the motor running....just wondered....thanks to all
Old 03-26-2017, 01:13 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Old 03-26-2017, 01:32 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Here is the proper way: https://www.ford-trucks.com/forums/1...l#post13491110
Stewart
dwstenersen
01-28-2017 01:07 PM
ramblin' guy
10-26-2008 10:34 AM
m.e.vinson
11-17-2006 06:18 PM
Rangerdad
1983 - 2012 Ranger & B-Series
09-29-2003 08:25 PM
mendeldl
Aerostar
01-18-2003 05:08 PM
Quick Reply: Brake Bleed
