31 vs C1 vs D1 Axles
Old 03-21-2017, 10:26 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
My E99 has axle code of 31, which checks out to be an open 3.73 for an F-250. I am eyeing up two different trucks, one with C1 axles and one with a D1 axles. Both are 3.73 LS, the C1 lists for use in an F-250 and the D1 lists for use in an F-350. What are the differences between all of these axles and can the C1 and/or the D1 carriers be inserted into my 31 axle housings?
Thanks for the help.
Old 03-22-2017, 08:01 AM
Walleye Hunter
Anybody? Surely someone knows about these rears?
Old 03-22-2017, 01:30 PM
Jesser02EX's Avatar
Jesser02EX
Jesser02EX is offline
D1: Limited Slip 3.73 F-350
31: 3.73 F-250 / Excursion
Axle code 31 doesn't say Limited Slip...
Got the information here: Identify Your Ford Truck Axle From The Door Sticker : Blue Oval Trucks
Old 03-22-2017, 04:35 PM
Walleye Hunter
Thanks, I have that part, I'm wanting to know if the C1 and/or D1 carriers would fit into my housings. Depending on the sale price of the trucks I could end up just swapping in the D1 axles out of the F-350. Is the D1 a Dana 80 and the C1 a Dana 60 or something?
Old 03-22-2017, 05:20 PM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
I would think that as long as it is listed as a Sterling 10.5 inch gear set it should be compatible with the housing, if that is your question. Is there a site for them listing available gear ratios?
Old 03-22-2017, 07:17 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
@pirate4x4_camo
Stewart
Old 03-22-2017, 07:32 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Originally Posted by Stewart_H
I don't have the codes memorized but to answer the OP question, if it is a SRW f350 then it is a sterling 10.5 and yes the limited slip will fit in your open and viseversa
Dana 80 only came in the dually.
1999-03 7.3L Ford Powerstroke Axles and Differentials
Old 05-01-2017, 02:45 PM
Walleye Hunter
OK, I need some detailed information on these rears. My truck is E99 w/3.37 open rears. Donor truck is '01 F-350 w/3.73 LS rears. I recall hearing that axles are one thing that changed mid year in '99 and I'd like to know what it was if anybody knows. Given that this is an E99 will that carrier out of the '01 still fit right in? And would it be easier/better to switch the axles out vs just the carriers? I'd prefer to just swap the carriers and keep the E99's wheels if possible.
@pirate4x4_camo
Old 05-01-2017, 02:57 PM
pirate4x4_camo
Check your axles BOM but I'm pretty sure the 99 is a sterling 10.25 and the 2000+ is a 10.5
Old 05-01-2017, 03:17 PM
Walleye Hunter
What is a BOM?
Edit: I found it, thanks!
Bennie Morton
1999 to 2016 Super Duty
04-06-2017 09:47 PM
46Whizzer
06-22-2016 03:53 PM
64 hi-boy
02-08-2010 07:59 AM
jj33s
03-04-2003 12:55 AM
wolverineflight31
12-08-2002 04:14 PM
Quick Reply: 31 vs C1 vs D1 Axles
