6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Diesel
Old 03-19-2017, 01:12 PM
Gertie12's Avatar
Gertie12
Gertie12 is offline
Diesel
I have a 6.4 diesel that had water in fuel. I have flushed the system of the water. I have replaced the fuel filters and the injectors but still will not start. Sounds like it wants to turn over but doesn't. Any help would be appreciated
Old 03-19-2017, 03:52 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
Are you cycling the key for 20 seconds about 6 times or more. When you bleed off the simple sep in the rail, air is not your friend. Try a repetitious cycle and look for leaks. Takes about 6 instances for me to get the air out when I pull my drain valve on the frame rail.
Did you use motorcraft filters???!!!
Denny
Old 03-27-2017, 06:43 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
theres going to be a lot of air in the injector fuel lines, the fuel rail, the fuel cooler, and both fuel filters.
do the cycling thing before you try to start it.
also, depending on the year 6.4, there's a fuel cooler bleed air valve that looks like a tire air fitting. once you turn the key and hear the pump whine.....dont try to start it...leave the key in the on position (but dont turn it to start it) and go out and while the pump is running, bleed the air out of the fuel cooler using the fitting.
then do the 6 cycles of on and off for 20 seconds...before trying to start it.
Old 03-27-2017, 08:58 PM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Ensure that you can hear the fuel pump on the frame rail, it will not activate if the fuel filter cap is not seated all the way.
bulletpruf
36
06-10-2023 01:20 AM
Gertie12
1999 to 2016 Super Duty
03-19-2017 05:13 PM
mtnbkr909
09-06-2016 12:35 PM
mx250racer1
03-26-2014 11:16 AM
blue_16v
52
08-18-2008 07:44 AM
Quick Reply: Diesel
