Coolant tube adapter for EGR cooler.
I have a blue silicone tubing on my EGR coolant line after I did my delete. The problem that I am having is the outside of this tubing keeps failing on me due to the hose clamp cutting through the side of it.
I purchased the shielded clamps that prevent cutting into this soft rubber, but I continue to develop leaks on this hose.
is there any other hose that is a little more substantial that still holds up to the heat? I believe that I am using the 5/8 hose, it seems to go on tubing quite tight, but fits the port on top of oil cooler quite well.
any suggestions would be appreciated.
thanks.
a new coolant tube adapter for EGR cooler.
thanks.
