94 7.3l idi build
Old 03-06-2017, 09:13 AM
x94f250idix's Avatar
x94f250idix
x94f250idix is offline
94 7.3l idi build
I have a 94 7.3l idi factory turbo. 170k. 4" exhaust. I'm told it was flanged and the 4" was made from the original so maybe it goes from original to 4"? Not sure. I recently think I blew the head gaskets so I'm going to pull the engine fix the head gaskets and my oil pan leak but I want to do some upgrade while I'm at it. Nothing crazy mild build mild budget. I know nothing about turbos other than what they do. As far as i know orginal injectors and ip. I was thinking head studs upgraded injectors and pump. Any suggestions
Old 03-07-2017, 01:25 PM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
Definitely get a turbo. ATS, Banks, or Hypermax are available used online a lot. You can also get nice upgrade kits from R&D Performance that will make more power than what was previously mentioned. It all depends what you want. R&D also has upgraded injectors and IPs.
Skate138
06-03-2012 02:58 AM
FordManMT
04-28-2011 04:13 PM
fordzilla01
53
09-03-2008 07:54 PM
deanzawistowski
01-29-2008 11:34 PM
1991f250
11-18-2006 01:07 PM
Quick Reply: 94 7.3l idi build
