Replace T case, now My trans shifts weird
Old 03-16-2017, 12:11 AM
madpogue's Avatar
madpogue
madpogue is offline
Wait wait wait. This....
Originally Posted by Jarkill
The shift plug looks like it could be plugged in either direction. Is it possible that it could be plugged in backwards? And would this cause the truck to shift erratically even when in 2x4?
... is in all likelihood your problem. The light switch/connector should NOT go in either way; the connector face should be somewhat "D" shaped. I suppose it's possible to force it in in the wrong direction. That switch is, in effect, two switches. In 4HI, some part inside the t-case pushes the plunger halfway, which connects ONE of the terminals to the base of the switch, which grounds that circuit. That should turn the "4x4" light on (but NOT the "LOW RANGE" light). In 4LO, that plunger is pushed further, which grounds BOTH terminals, which turns BOTH lights on. The "LOW RANGE" light wire also goes to the TCM, which tells the tranny to shift at lower speeds.
So imagine if the connecter were plugged in backward. You shift to 4HI, the plunger goes in halfway, that terminal on the connector, which SHOULD be grounding the "4x4" light circuit, is instead grounding the "LOW RANGE" light circuit, and in turn, is falsely telling the TCM that you're in 4LO.
So before going into any surgery with the speedo cable, gear, sensor, etc., turn that connector around 180 degrees and see what happens.
Old 03-16-2017, 05:22 AM
chillman88's Avatar
chillman88
chillman88 is offline
10-4. I had a feeling so I kept the old Speedo unit. I'll pop that in next. Also, I went ahead and plugged the 4x4 sensor plug in the other way and that cured the 4 wheel drive light problem. Thanks for the input!
He already did flip it around. I was hoping it was that simple too...
Old 03-16-2017, 07:38 AM
madpogue's Avatar
madpogue
madpogue is offline
Eeek, misstd that!.....
Old 03-16-2017, 09:08 AM
Jarkill's Avatar
Jarkill
Jarkill is offline
Haha! Easy to do when the threads get lengthy. Yeah, got that sorted out. Almost done updating my charging system. Should be able to drive the beast tonight and see if the speedo gear fixes the issue
Old 03-16-2017, 02:06 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
also, When I removed the ring gear from my new/used T case, It was the same yellow gear but its pretty worn down and almost flat in some. That explains my speedo needle jumping around, but could that also affect the shifting?
Old 03-16-2017, 03:12 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
Old 03-16-2017, 04:20 PM
chillman88's Avatar
chillman88
Well I'm going to assume that Ford color codes its gears just as GM does. If that's the case and they were both the same color then I would assume that it wouldn't make a difference.
Is that shift thing that the E4OD trucks have on the throttle properly adjusted? FIPL maybe? Don't remember, I have a 5spd so I haven't paid much attention to the auto specific stuff...
Old 03-16-2017, 04:29 PM
Jarkill's Avatar
Jarkill
Jarkill is offline
It all started after i replaced the T case so I just wanted to eliminate all possible T case related causes. If this aint the fix, then Its on to TPS/FIPL. last time I tested it, it was good. But, that don't mean it STILL is
Old 03-16-2017, 07:28 PM
chillman88's Avatar
chillman88
Yeah I know but I'm kinda out of ideas...
Old 03-17-2017, 08:50 AM
Jarkill's Avatar
Jarkill
Jarkill is offline
No worries and thanks for the help!
IT'S FIXED!! It was the ring gear being worn. She shifts real nice once again!
Thanks everybody! Beers on me!
Old 03-17-2017, 09:14 AM
chillman88's Avatar
chillman88
Awesome! So glad to hear that!
(So how far do I have to drive for my free beer he he he)
Old 03-17-2017, 09:41 AM
Jarkill's Avatar
Jarkill
Jarkill is offline
eastern washington. I'll keep it cold for ya
turboseamus
1999 to 2016 Super Duty
01-06-2018 11:18 AM
trevorrules
07-18-2015 05:10 PM
Hoseman
1997-2006 Expedition & Navigator
07-08-2009 01:04 AM
Spktyr
05-13-2004 09:04 PM
AbadDriver
Bronco II
02-03-2003 08:16 PM
Quick Reply: Replace T case, now My trans shifts weird
