fly wheel installation question
I believe this is the
Engine Crankshaft Reinforcement Plate
Searching for correct placement of this plate is confusing me, I'm getting different info.. This is a ZF5 Manual.
There is evidence that the reinforcement plate was installed in between the block, and the Flywheel. Not so much evidence of it being installed in between the flywheel and the clutch. which side of the flywheel is this ring supposed to go????
See photo's below. You can see Sharpy marks on the flywheel that shows me someone torqued these once.. marking bolts that were torqued, also, I can see bolt head evidence. The reinforcement plate covers those marks..
Just changed the clutch on my 97 and the spacer was behind the flywheel, meaning block, flywheel, then the plate. I converted to a SMF instead of the dual mass and I feel like I have some memory of not reusing it but I know that isnt right. But I know if came off before the flywheel.
The following users liked this post:
Johnkimble
20
09-07-2018 11:48 AM
AtlM5
05-16-2015 08:36 PM
crazy96863
05-10-2013 06:19 AM
crazy96863
05-01-2013 09:11 AM
