Gauge vs. Sending unit
Albuq F1
Your advice and Fig. worked like a charm. My shop manual had a different version of Fig. 93 and it wasn't as clear as your directions. So I was able to determine that all three gauges did work when I tested them. After spending the day under the dash I was able to determine a couple of modifications that were made to the original wiring. Someone along the way installed turn signals and a speaker in the dash. I was also able to determine that the 6 V system is a positive ground system. At this point am I wrong to assume that with the modifications made to the system that it's probably the ground that is faulty for the panel? I tried to trace the ground wire From the three gauges but it led to a wrapped bundle and it was tough to tell but it seemed to lead to the ground on the back of the firewall right underneath the regulator. Is this where the instrument panel is typical grounded? I guess my big question is how do I test to make sure that is a good ground and is it different because it's a positive ground system?
thanks again!
thanks again!
I should have stated my diagram is an edited version specifically for using a battery.
For the BonusBuilt trucks, the ground for the instrument panels/gauges are pretty much the retaining clips holding them into the dash. I don't recall a dedicated wire for grounding. That's why there are often gauge problems after painting. You can certainly run a ground wire to something under the dash that is clean steel.
The wire going to the ignition switch is NOT a ground, it's hot (power). What year is your truck? on 48-52's there is a sheet metal strap, not a wire, from that terminal on one gauge to the other gauges to power them. The ground is the case of the instrument to the dash (or add a wire as I added above).
Really Abe thats not what I took form his post! I'm obviously new at this and am really trying to pick it up and do it myself. If you are frustrated with the questions I'm asking feel free to troll a different post.
Ross thanks again for taking the time to help me out, it's very much appreciated.
Hi there Pezlo,
Do you have a voltmeter or test light to see if power is getting to the gauges?
Power from the ignition switch should be to the gauges when the ignition is in the "ON" position. And as Ross stated, power is connected from gauge to gauge with metal strips. This is where I would test first. Your grounding is probably ok.
...Terry
...Terry
