1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
FORScan agrivations, sees bt adapter, no vehicle connection - help
Old 03-01-2017, 12:13 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
ok for what ever reason, I seem to not be able to get ForScan to connect to see the truck so I can see what options I have to play with and perhaps enable a few things in the GEM like the door chime or what ever, anyways I can get the program to see the OBDLink MX which is good, however every time I tell it to connect to the truck it says it can't establish communication, and then to check the truck is on, well its on as I got my music player sat nav going...
I have uploaded the connection.txt file in hopes you guys ight be able to assist with getting this going, other times it does say "no ELM found" but I don't think that's causing an issue as the truck knows to use the ELM 372 settings when it is connected to the OBDLink MX
Anyways thanks for the help guys!
File Type: txt
Connection.txt (865 Bytes, 158 views)
Old 03-01-2017, 03:05 PM
Tampora76's Avatar
Tampora76
Tampora76 is offline
Try going into the Forscan settings and make sure you have your OBD adapter as the device to connect to.
Old 03-01-2017, 05:29 PM
Jaime74656's Avatar
Jaime74656
I do currently have the Bluetooth adapter set to the OBDLink MX in the settings.
Old 03-01-2017, 11:36 PM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
I have two bluetooth adapters. One is white and has a power switch, the other is a much larger blue one that has "Vgate" on it.
The white one doesn't work and will only display 3-4 PIDs.
troverman
2017+ Super Duty
04-10-2017 06:07 PM
jggearhead
6.7L Power Stroke Diesel
09-16-2011 08:49 AM
c4barnes
New Hampshire Chapter
40
04-04-2008 08:58 PM
cowlady
New York Chapter
10-06-2004 10:57 AM
White_Knight
Oklahoma Chapter
02-12-2004 04:32 PM
Quick Reply: FORScan agrivations, sees bt adapter, no vehicle connection - help
