2001 E350 7.3 Transmission Not Shifting Properly
I recently purchased a used 2001 E350 with a 7.3L and the transmission is not shifting properly. It will go into Reverse no problem, put it in "D" and it starts in high gear and will not shift out. If I manually shift from 1 to 2 to "D" it works fine and will even go into OD. It will not down shift on its own either. What should I do to fix this issue?
bandlgeorge
08-11-2015 11:11 AM
brendo907
06-20-2015 08:49 PM
