'92 swing clutch pedal in '56 F 100?
I am putting a 300 6 and M5R2 5 speed in a 56 F 100. I have 2 parts trucks- a 85 f150 (using Engine) and a '92 F150 ( using transmission). I have removed the swing pedal assemblies from both parts trucks. The 92 brake/clutch assembly looks pretty compact and might work on the firewall of the 56. Has any of you done this? I will post some pics soon of what I have. Thanks Greg
Nice heres some pics of what I have. I just temporarily put a bolt thru a existing hole. Have no idea if this is close or not. My seat is out of the truck. I will put it back in and see how it fits.
It worked out great for me. I hove pics but they are buried on my computer and in my build thread below. I will try to post some pics or you can look at the build thread- though it has gotten pretty large. Anyway I used whole assembly out of the 92 F150, except for the bigger booster that is in the pic earlier on this thread. I used the booster from a 93 or so Ford Ranger- It is smaller as they collided with the support rod that goes from the firewall to the rad support. I ended up bending the rod some even after using the smaller Ranger booster. The only thing I don't like about this setup is the brakes are really touchy- you will get used to them, but if someone else drives truck they will put you thru windshield on 1st stop! I'll see if I can get some pics out of the thread. Good luck.
Booster
Ok look on the basket case build thread post # 39-42, 47-( bigger F150 booster which I didn't end up using), 58, 113 (this is a pic of smaller Ranger booster and master cylinder- but I ended up using smaller Ranger booster with F150 master. Hope this helps.... clear as mud....
mcdimen
08-24-2014 11:16 AM
joners
23
05-12-2004 03:40 PM
