New carb, runs great, fuel additive?
Old 02-25-2017, 05:37 PM
Buildingdavej's Avatar
Buildingdavej
Buildingdavej is offline
Just put a rebuilt OEM carb on my 79 F-250 460 4bbl. Started to go with the Holley but really want to stay very stock so I went with the OEM rebuild from RockAuto. Runs great now, but I'm concerned because of the ethanol in the fuel now. I can't find ethanol free gas here in NorCal so I'm curious about which additive has worked best for everyone else.
Any thoughts!?
Old 02-25-2017, 06:35 PM
79 ranger 4x4's Avatar
79 ranger 4x4
79 ranger 4x4 is offline
Startron is a fuel additive I use. I'm a service tech for construction equipment and we have a ton of small engines in water pumps pressure washers ect and water was a Definate problem with ethanol. Startron is a enzyme based treatment that attacks water and makes it able to run in the engine with no negative effects plus it's a stabilizer as well.
Star Tron® Enzyme Fuel Treatment is a revolutionary fuel additive that utilizes enzyme technology to enhance the performance of boats, automobiles, trucks, RVs, tractors, farm equipment, generators, lawn mowers, lawn equipment, oil burning furnaces and all other small engines.
Old 09-18-2018, 02:38 PM
Miker51's Avatar
Miker51
Miker51 is offline
How about for E10 that's been sitting for 6 months? Thanks!
Old 09-18-2018, 05:57 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
If it has not gone gooey but lost it's fire throw some coleman camping fuel in it. That will bring it back to life.
Old 09-19-2018, 02:51 AM
Edward Michael's Avatar
Edward Michael
Edward Michael is offline
Installed the factory 4 barrel from vapex at $600 as they pre tested the carb on a 460 in their shop for the dreaded vacuum leak at the throttle body, which throws the numbers on the smog machine not to mention everyday performance.
Went through 2 carbs from summit for around $300 and finally had it with the remove, ship back, reinstall, go back to the smog shop (this was on my 85 f350).
Anyway, the idea of running the “new” gas in this costly investment steered me to the Lucas fuel additive. Buy it buy the gallon and been running it in my dual tank 85 f350 and 87 f150 with noticeable positive effects. Also, run premium gas.
Not sure that its really doing anything. But the trucks run great even after sitting for a couple weeks.
Please, anyone have information that this is NOT beneficial and a waste of money... let me know.
Old 09-19-2018, 05:10 AM
matthewq4b's Avatar
matthewq4b
If the vehicle is used frequently then yes it is a waste of money. If it is not used frequently then it is good insurance.
Old 09-19-2018, 12:19 PM
XSoph's Avatar
XSoph
XSoph is offline
Here is a user-maintained list of ethanol-free gas stations. See if your region is on the list:
https://www.pure-gas.org/
Accidentally posted this reply in the bullnose forum this morning.... infinitely scrolling forums, plus mobile web browser get's me lost sometimes...
Old 09-19-2018, 01:27 PM
beartracks's Avatar
beartracks
beartracks is online now
Treatments don't work well on old fuel. Add with the gas for best effect. Chevron Techron is good. I also like Seafoam.
Old 09-19-2018, 02:09 PM
79F150400M's Avatar
79F150400M
79F150400M is online now
I guess I'm lucky that I have a Cenex Co-op nearby to buy my eth free gas....I use it in my truck, lawnmower and chainsaw.
Old 09-19-2018, 05:02 PM
Dave145's Avatar
Dave145
Dave145 is offline
Any fuel additive is really a waste of money. Once gas is bad it's bad. The additives will just mask that by adding a bit of octane to the gas.
Stabil works for gas that needs to be stored throughout the winter. At the very least it seems to keep the moisture out.
Ethanol treatments aren't really needed. These things run fine on ethanol if it's tuned properly.
Old 09-19-2018, 06:29 PM
matthewq4b's Avatar
matthewq4b
Not quite true, depends on the fuel. Some fuels will oxidize badly due to the additives used in it this is a problem with premium here where it has shelf life of about 3 months. Many times the fuel loses it's lighter hydrocarbons through evaporation and won't fire, but they can be replaced by adding a lighter hydrocarbon such as white gas/coleman fuel, a few ounces per gallon is all it takes to put the fire back in the fuel. So if the fuel still looks like fuel and has not gone black or brown or red from rust and has no globules floating in it, it can be salvaged.
Old 09-20-2018, 05:38 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
I think the best thin to keep it happy is to run it enough the fuel does not go stale. No additive needed. The carb should/would have been rebuilt with E10 compatible parts.
Berlin76
2017+ Super Duty
24
11-10-2017 10:31 AM
Icthus in AK
6.7L Power Stroke Diesel
11-11-2015 12:04 PM
Glockin' Bob
09-21-2011 06:55 PM
mariosb11
1999 to 2016 Super Duty
01-15-2009 02:33 PM
TxFordGuy
Bio-diesel, Propane & Alternative Diesel Engine Fuels
08-16-2008 04:54 PM
Quick Reply: New carb, runs great, fuel additive?
