Over-voltage at the coil
I've been having consistent ignition problems on my 1979 400. Early last summer, it cooked an ignition box. In the fall, it cooked the coil. I haven't taken any action on it this winter, but in the spring, I'm going to drop a new coil in it and start it up. In preparation for doing so, I decided to take some measurements and see if I could figure out why I keep having ignition woes. It turns out I found the problem - on battery voltage (12.6 volts measured between the posts), I get 11.9 volts at the coil connector with the key in the Run position, which implies to me that the ballast resistor wire has been bypassed. My question: What's the best approach here? Is there an easy place to splice in a ballast resistor under the hood, or should I look for a high-resistance (3-ohm) DSII-compatible coil? Does such a thing even exist?
In the 80's the DS-II ignitions had a 1.1 ohm resistor in the wiring, as shown here: Start, Ignition, & Carb Circuits - ???Gary's Garagemahal. I'd look for a stand-alone resistor of about that value.
You have a few options here:
Option: You could run an HEI distributor and take the coil, ICM, ballast resistor wire and accompanying wiring variables out of the start/run equation.
Option: You could replace the OEM ballast resistor wire.....D7AZ-12250-A, or Motorcraft #DY-213. RED/green stripe, 4' 1" (49") long, 16 ga wire, ~ 1.5 ohms. It runs from the ignition switch (two R/g wires connected together) - one goes to the resistor bypass on START, the other ties into the coil (+) providing < 9VDC in RUN. You could chase this down...under the dash....and splice it in/replace the old, shorted out one.
What happens is the OEM coils and most aftermarket ones have ~ 1.5 ohms resistance built in. You'll fry the coil if it gets battery voltage. It's meant to run on < 9 VDC and gets an initial 12 VDC only in START. The DSII is a good unit when properly maintained.
Option: You could obtain a Mopar ceramic ballast resistor.....1.5 ohms.....chase down the old wire and splice it in. It usually mounts on the firewall..... gets pretty warm so mount it away from sensitive wiring.
Fordboy88
07-06-2013 11:39 AM
pburress
27
11-27-2012 08:13 PM
