How resilient are 400 crank shafts?
What are the chances of the crank in an old 400 being serviceable? I'm looking to do a 351m -> 400 conversion but availability of 400 cranks is limited. I see a lot of 400 motors for sale, often not much more than a crank. Of course, all say, "running when it was pulled".
My 351m is in good condition so I'm hesitant to do a full swap. I know a lot of people will recommend throwing in a 460 but I like the 335s. I don't need to build out a 400 hp monster and keeping my MPG over 10 would be nice. With the 400 and TDC timing it should do what I'm looking for.
Thanks!
Thanks!
Yup, pretty much somes its up. The stock 400 crank has been used, and shown reliable in some crazy engine builds, upwards of 500hp.
Idk
Studding the bottom end for a small rpm motor is tad overkill ya? Fresh bearings and a grind (if needed) should be fine on a daily w mild cam i would think (check cam bearings too)
Tartersauce53
15
04-11-2017 09:55 PM
MattMac
02-23-2017 08:00 AM
78MeanGreenBronco
24
11-23-2008 06:28 AM
78f250lj
18
02-19-2003 09:34 AM
