2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
How much hitch drop
Old 02-25-2017, 01:36 PM
White gold's Avatar
White gold
White gold is offline
How much hitch drop
How much hitch drop are you finding that you need on the new 250 SD ?
Old 02-25-2017, 01:49 PM
Stalwart's Avatar
Stalwart
Stalwart is offline
Depends on the trailer and the wheel and tire combo on your truck.
Old 02-25-2017, 02:02 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
3" more than my 2016 250 needed.
Old 02-25-2017, 02:11 PM
White gold's Avatar
White gold
I had a 4" on my previous Ram 3500 , but dont think it's gonna be enough on the 2017 super duty.
Old 02-25-2017, 02:35 PM
K A M's Avatar
K A M
K A M is offline
With a 2" ball hitch you want the top of the ball approx 18" from the ground loaded With a 2-5/16" ball hitch you want to be at 21"-22" from the ground to top of ball loaded. Get your drop hitch measurement from these numbers.
Old 02-25-2017, 02:48 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,198 Likes on 573 Posts
Many of us went with an adjustable drop Weigh Safe that maxed out at 8" drop.
Old 02-25-2017, 02:54 PM
tw450's Avatar
tw450
tw450 is offline
Yes I got the 6" weigh safe and have been on the last notch already in just the few times I've used it.
Old 02-25-2017, 02:57 PM
System's Avatar
System
System is offline
Prolocutor
The most I ever needed with my 2012 350 was a 6" drop. So, the new receiver being exactly 2" taller told me that the most I'd need with my 17 is an 8".
Old 02-25-2017, 03:45 PM
KNGRNCH's Avatar
KNGRNCH
KNGRNCH is offline
The top of the hitch receiver on an F350 CC with 20" wheels is 24" (give or take a fraction) above the ground. The ball receiver on a small trailer (like for hauling a mini-excavator) is about 16" above ground level, so an 8" hitch drop keeps the trailer level. I haven't done it, but I assume that raised all the way up, the hitch should work with a larger trailer with a ball receiver 24" above ground.
Old 02-25-2017, 03:48 PM
System's Avatar
System
System is offline
Prolocutor
They do make a 10" but Weigh Safe doesn't recommend it as will likely have ground contact in certain situations.
Old 02-25-2017, 04:22 PM
Kenv's Avatar
Kenv
Kenv is offline
7" Drop B&W Tow and Stow here. F250 HD tow package. 285/65/20 tires.
Old 02-25-2017, 04:28 PM
Texmudder's Avatar
Texmudder
Texmudder is online now
I had to go from a 4 inch drop to a 6 inch drop.
Old 02-25-2017, 05:11 PM
White gold's Avatar
White gold
Is anyone using the 7" B and W tow and stow ?
Old 02-25-2017, 05:16 PM
MagneticTiger's Avatar
MagneticTiger
MagneticTiger is offline
Has anyone had any hesitation with an aluminum shank? I told my buddy I was ordering an aluminum hitch, and he had a mini- stroke, claiming I would die, and I would kill my horses when the hitch broke... Any truth at all to this? I am a big believer in Aluminum!
System's Avatar
System
System is offline
Prolocutor
Um, two posts up? LOL
Quick Reply: How much hitch drop
