ficm testing
ficm testing
I never tested a ficm before and just want to make sure before getting it repaired.
I had 48.5 volts with the key on and while cranking went to 49.6 volts.
while holding it on for a second time it went to 30 volts and jumping around while cranking and then to 49.5 and the truck started and it was at 48.5.
One other thing is my injectors are chattering when the key is on but not all the time. (not sure if this is normal)
If the ficm is bad and someone recommend a ficm repair shop.
Thank you for helping this truck is non stop with repairs I need to start working on it myself.
You need to test the FICM after a cold soak.
Then start it up after cold soak and see what your FICM puts out for voltage.
- Preston
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts ftw!
King of the Road 04
11-27-2010 02:06 PM
