Possible LPOP Failure--BOPAS
Old 02-21-2017, 01:34 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
I figured I'd start a new thread that is more relevant to what is going on with Whitey...which I have appropriately renamed B.O.P.A.S for Big Ol' Piece Of Sh**
I discovered my reservoir is empty, so the truck is running out of oil. I checked the oil filter housing valve, and it's good. It is either the HPOP drainback valve has failed or the LPOP is toast. Here is my thinking....come tax return time, it's getting a T-500 and a melling LPOP, whether it fixes the problem or not. Here is my reasoning. It has a JY HPOP in there now, which runs good, but is questionable. A new T-500 is an upgrade as well as an elimination to being stranded. A new LPOP is cheap enough and easy enough to replace and its one less issue that can leave me stranded. After the breakdown in El Paso and ALMOST being stranded again yesterday, I am over it and my confidence in this truck getting me and my family somewhere safely is waning.
I did get the PO on the horn yesterday to ask him some more history about the truck. Come to find out he used Lucas on EVERY oil change!!!
That would have been a deal breaker for me had he provided me with that little piece of information. He swears up and down that he did not ever change the HPOP though Adam and I pulled a re-manned one out of there. I think he's trying to cover his azz....ah well, can't paddle my canoe backwards, but now I have to have a plan from here on out. I guess I am also going to spend a good 1000 bucks on spare parts...if I even keep it at this point.
SO, to recap...LPOP issue and oil filter housing checks out. Even if HPOP drainback valve is good or not, it's getting a T-500. It's getting a new LPOP whether it's the issue or not just due to the oiling problems this truck has been having. It might be...MIGHT be that the LPOP took out the last HPOP. It has been mentioned in my texting network. It's just really REALLY odd that this truck has had two HPOPS in 160k miles. It's on it's third one.
DO NOT use oil additives in your truck if you are reading this and have fallen for some Saturday diesel truck show horse ****. That is all.
Old 02-21-2017, 03:14 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
I think that the metal shavings did brake havoc on old Whitey. Try changing the oil filter and go from there.
Old 02-21-2017, 07:58 PM
BBslider001
You may be right. I changed it three times now. When I took it off this morning, the oil was like honey. Hopefully the trouble is behind me and I am just playing catch up.
Old 02-21-2017, 08:40 PM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
Have you cut the filter open? Are you seeing it catch shavings at all?
Old 02-21-2017, 09:36 PM
BBslider001
I haven't. No reason it wouldn't though. Oil is clear as honey after last change. It was clear last change, but I changed it anyway.
Old 02-21-2017, 09:40 PM
PSU4ME's Avatar
PSU4ME
PSU4ME is offline
I was just wondering how much it's catching. I'm sure the filter is doing its job. Hope you get this sorted out soon
Old 02-21-2017, 10:47 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Was the PO the orginal owner? Is it possible all the filing from the blown hpop took out the lpop? Good luck Byron, I feel for you!!
Old 02-21-2017, 11:11 PM
BBslider001
Thanks Bryan. Whitey's in time out right now and he's gonna have to earn his name back LOL
It'll get worked out.
Glenn, this is very possible. It's also been mentioned the reverse happened. Oil is clean now, more than ever.
Old 02-22-2017, 10:16 AM
z31freakify
This is the hpop from Byron's truck
Old 02-22-2017, 10:27 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
It would take the smallest piece of debris to stop the anti drain back from working plus I'm pretty sure that the hpop gets fed with unfiltered oil. I think I would flush the system if possible. One other thing to consider is a broken oil pick up tube. If that happens you can end up with air bubbles in your oil. Good luck byron.
Old 02-22-2017, 07:40 PM
BBslider001
Thanks Nick. I did as much of a flush as I could I think. Oil looks like honey. I'll send a sample into Blackstone as soon as I can get him up and running again and put some miles on him.
I kinda doubt my pick-up is busted with the low miles....at least I really hope not.
Old 02-23-2017, 10:21 AM
MOOSE_MACHINE
True. But there is also a gasket at the top of the pickup where it mounts to the front cover
Old 02-23-2017, 01:10 PM
BBslider001
Well just keep hoping the worst for me man...good grief
Old 02-23-2017, 07:35 PM
fordpride's Avatar
fordpride
fordpride is offline
Have you had a chance to test the LPOP?
Old 02-23-2017, 10:26 PM
BBslider001
Mike I haven't. I have zero time this week and it's getting replaced whether it tests good or not just due to the history of oil issues. I may test Sunday when all the craziness slows down.
Quick Reply: Possible LPOP Failure--BOPAS
