Pro Comp 22410's
Pro Comp 22410's
Hello all, my name is Mason and I'm a new member to the forum although I've been to the site many times before. I have a 2000 F350 7.3 ccsb srw, with 215,000 miles on it. I am planning on installing pro comp 22410 springs on the front with an adjustable trac bar and bilstein shocks. The rear springs are completely shot with a couple leafs broken off. The truck is used to tow occasionally and I need new springs for it. I had planned on removing the rear 3.75" blocks and installing the pro comp 22415 springs in the rear rather than using oem springs but was told this would not work. I plan to put 35's on it and wanted enough clearance in the front, which the 22410's will provide but Im not sure exactly what I should do to achieve a level stance, or even a slight rake. Any thoughts would be greatly appreciated!
