hydroboost conversion 88f350
that....rocks.
thats a 7.3 in the falcon??!!
let me see about the pressure port on gear box, it should be a 5/16 inverted flare making the thread 1/2-20
also fyi i see your welds are just beautiful on the front tie in cross member so you likely wont need this info but
but if you are looking for a hydro boost pedal, i got one -new from ford.for the 87 -97 series manual trans.
on the pressure side of the steering box, i used fords hose and fittings. my truck's all factory anyhow , but ford might not be the right length for your custom thing there?
yes sir.
just an ole IDI and ZF5.sitting on a 89 F350 chassis.
i don't have much room in the Cruck, so i had to adapt the hydroboost to the stock pedals.
i needed to drop the PS lower than stock to make way for the twin turbo set up im doing.
check it out when youre free
https://www.ford-trucks.com/forums/1...gine-swap.html
coreyallan01
06-24-2014 01:18 PM
Boltgunner
36
04-17-2006 12:19 AM
Boltgunner
03-04-2005 02:04 AM
