1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2016 center seat swap with pre 2011 console
Old 02-14-2017, 08:10 PM
inlovewithfishin's Avatar
inlovewithfishin
inlovewithfishin is offline
Ive done some searching and I can't find any information about possibly swapping an older (pre 2011) console with a 2016 center fold down seat. The reason I am interested in doing this is because I can't justify spending over $1k on a used 11-16 center console.
this may be a dumb question... but is there any chance 11-16 f150 shares the same console as the super duty? they look very similar!
Thanks for any help! Just picked up my 16 f250 6.2 XLT crew cab short bed 4x4 this weekend and I have a few items I would like to upgrade.
Old 02-15-2017, 08:04 PM
cabindoc's Avatar
cabindoc
cabindoc is offline
The F150 stuff will not fit. I did a 2008 center console in a 2012. Not sure how much has changed from 2012-2016. I also swapped a seat for a flow through console on my 2011.
Not sure if this helps. The older consoles are getting harder to find. Yes the flow through's are pricey, but be vigilant and maybe you'll luck out.
Old 02-16-2017, 08:11 PM
inlovewithfishin
Thank you very much! that helps a bunch... If you fit a 2008 console in a 2012 then i should be able to fit an 08-10 console in my 2016. Any chance you have any pictures?
Old 02-17-2017, 07:02 PM
cabindoc's Avatar
cabindoc
cabindoc is offline
I have a whole write up on it. See attachement. It is on a flow through (newer) on an 11.
Old 02-19-2017, 08:32 AM
inlovewithfishin
thank you for your help!!! that is exactly what I am looking to do
Old 02-19-2017, 10:06 AM
eberlestock's Avatar
eberlestock
eberlestock is offline
I have sapped out consoles on 3 dutys now. I buy them at auto wreckers. 2008-10 consoles go for about $350-450 and the 2011-16 units go for $4-500.
Old 02-19-2017, 06:20 PM
cabindoc's Avatar
cabindoc
cabindoc is offline
Had to take mine out today to run some cameras up into the radio so here are some more pics. will be doing a write up on the camera adds when I'm done.
Old 02-19-2017, 07:06 PM
inlovewithfishin
thank you guys!!! I need to find a junk yard that will have some super duty trucks to pick thru!
Old 07-23-2017, 11:11 PM
DirtWorx's Avatar
DirtWorx
DirtWorx is offline
SORRY for bringing this back from the dead, but what all is needed to put the 08-10 console in a 2012. I just picked one up on eBay, comes with the front and rear brackets, just curious what more I will need to make it work. My truck is a 2012 F250 XL with the 40,20,40 front combo. Any details would be awesome before I tackle this project.
Old 07-24-2017, 07:15 AM
cabindoc's Avatar
cabindoc
cabindoc is offline
Not knowing what you have, can't answer what you need. If it is your intention to hook up vents so that you will have air coming out the rear, then you need to read my article. There are several dealer parts required to make the connection work. Otherwise, there is a price that goes on the dash that replaces the cup holder. You will need that. Otherwise you should be good.
Old 07-24-2017, 08:56 AM
DirtWorx's Avatar
DirtWorx
DirtWorx is offline
Thanks for the reply, I have a 2012 F250 XL, with a jump seat. The console I bought is a 2008-2010 w/out vents. I wasn't crazy about the flow through console, so I pick up one from an 2010 just like the black console picture a few post up. I was just curious if it's a direct swap with the jump seat or if I have to fab some stuff up to fit the older console in my 2012
Old 07-31-2017, 05:52 AM
cabindoc's Avatar
cabindoc
cabindoc is offline
I don't think you will need anything else. Go for it!
Old 08-13-2017, 08:40 AM
DirtWorx's Avatar
DirtWorx
DirtWorx is offline
Okay so I went to tackle installing at 08-10' console in my 2012 F250 xl, the front bracket does not fit at all. When the console is sitting where it needs to be the back bracket is perfect but there is a minimum of 2 inches up and 1 inch back on the front bracket from where it needs to be. Do I trash can the front bracket and just run the rear one or is it because the XL is different then an XLT?
erikkes1
2015 - 2020 F150
03-01-2018 07:52 AM
DirtWorx
01-21-2018 11:28 AM
mustang9701
04-04-2016 10:15 AM
WABowHunter
6.7L Power Stroke Diesel
10-09-2013 11:38 AM
dweems
05-29-2011 06:02 PM
Quick Reply: 2016 center seat swap with pre 2011 console
