D44 spindle interchange 79 vs 95
In the process of prepping things for my swap this year on my '95.
I am curious if anyone can tell me would it be possible to swap D44 spindles from a 1995 D44 TTB axle to a 1979 D44 solid axle?
*edit for clarification*
I want to unbolt the complete knuckle/spindle assembly off the 1995 TTB D44 axle, and swap on to the 1979 D44 solid axle. Reuse factory axle shafts.
Reason for spindle swap is I want to update to the 1995 caliper design vs the '79 setup. Don't see any major differences in the rotor.
*edit*
In looking at the knuckle U joints, I am seeing the same ones are used for the '79 and the '95.
*edit*
Last edited by eliteman76; 02-13-2017 at 10:08 AM. Reason: Clarification of question.
Received 3,117 Likes
on
I was reading last night about found some links on the full size bronco forum but not had a chance to look at it. Something to the effect some stuff will interchange but I want to say the actual knuckle itself is different.
I was really hoping to use my '95 disc brake setup on the '79 housing.
I did see some stuff on adapting chevy 8 lug D44 stuff but why would a guy want to run 8 lug on a D44??
mofoco1
19
12-18-2016 01:18 AM
eliteman76
12-02-2014 01:06 PM
bmarkline
08-06-2008 11:46 AM
MustangGT221
01-19-2005 04:34 PM
