1978 - 1996 Big Bronco
5.8 trouble shooting
Old 03-18-2017, 01:49 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
1996 Bronco 5.8 with E4OD
The engine currently in the truck is a replacement engine installed about 7 years ago. Within this time period I hardly drove the Bronco, so in
a sense the truck sat idle. I started driving the truck daily about 4 months ago and the other day a condition started.
1. The truck idles fine, without a sign of a misfire and no noises that would indicate a problem.
2. At 1500 RPM there seems to be a noise that sounds like a damaged bearing rotating/tapping.
3. At 1500 RPM under load there seems to be a miss (like the truck is running on 7 cylinders) and a lack of power.
The conditions occur AT 1500 RPM and above.
Could this be a valve train issue? Distributor? Oil pump?
I donʻt think any accessory belt driven part(alternator, AC compressor, power steering pump, water pump, etc) would cause a miss.
So what else would cause a "squeak/tapping" internally with in the engine?
Old 03-24-2017, 02:29 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
when was it tuned up last? how about oil change? probably wouldnt hurt to replace the fuel filter as well.
Old 06-26-2017, 10:42 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
There was a damaged header gasket, yes, and the fuel filter was replaced and the
injectors were cleaned. The CAT may have to be replaced since it is causing a CEL right now.
It runs good for now, but itʻs life as a daily driver may be limited in the near future.
rbarbeau
13
04-10-2018 12:22 AM
WhyFord
28
08-12-2012 07:53 PM
Catatonic 515
08-07-2011 06:14 PM
Death85e
06-23-2011 12:17 PM
KhanTyranitar
Aerostar
06-14-2010 09:58 AM
Quick Reply: 5.8 trouble shooting
