Radiator crapped out
I don't think the baffles are needed if all you're ever doing is flying down the highway at 70.
However, they're important when you're moving slowly; stopped in traffic; or are trying to back a heavy trailer up a hill on a hot day. They help the cooling fan to pull the maximum amount of air through the radiator, transmission cooler, oil cooler, and A/C condenser.
I am betting your operating temperature climbs much quicker without them in those circumstances. Probably even more so in Texas...
Originally Posted by RainDesert
How much do you think you have lost?
My lower one just hangs out below the bumper area from when I installed my ranch hand bumper. I still have my side baffles..
My my transmission runs right around 200 with the highest being 209 with a head wind.
My coolant temps are around 175-180.
I think the lower one is to keep road debris from hitting the bottom end of the coolers.
The manual says "no" just change it at 105,000 miles
Do not use alcohol, methanol, brine or
any engine coolants mixed with alcohol
or methanol antifreeze (coolant).
Alcohol and other liquids can cause
engine damage from overheating or
freezing.
• Do not add extra inhibitors or additives
to the coolant. These can be harmful
and compromise the corrosion
protection of the engine coolant.
freezing.
You made it longer than I did one time .I bought a 2006 F450 6.0 and the radiator crapped out in the parking lot at the ford dealer with 60 miles on it. Since it was a custom bed truck, I had to wait a month to get it fixed due to shortage of parts instead of the lemon law. that truck should have been painted yellow with a rine texture.
AKFORD4x4
07-04-2008 06:47 PM
