U bolt torque
U bolt torque
Anybody know the torque spec for the rear U bolts? Also the center bolt. Got the parts from Mid-50's with new bushings, pins, locker nuts, center pin and U bolts . Looks like grade 5 U-bolts and I think 7/8's 14 thread. I looked on line but the numbers are all over the place. I did a search on FTE and got nonsense.
Thanks.
Thanks.
Yeah, I saw that too. Just not sure what a "Spring Clip Nut" is. Seems low for the U bolts. I was thinking something around 200.
RECOMMENDED U-BOLT TORQUE
Recommended U-Bolt Torque
For Cold-Formed U-Bolts
For Cold-Formed U-Bolts which have been torqued to a set preload are recommended to be re-torqued after a short time to take up the stretch in the set of the material.
U-Bolts that have been well lubricated with an anti-seize compound will have a torque range between plated and unplated values. All the above values are general guidelines.
The OEM Service Manual on specific models always takes precedence over values shown.
U-Bolts Must Be Tightened and Torqued Using A Cross Pattern Sequence
Snug U-Bolts in the seqence shown.
Tighten completely in the sequence shown.
Check U-Bolts for tightness after 100 miles
SIZE MATERIAL GRADE MAX. TORQUE FT. LBS. PLATED MAX TORQUEFT. LBS. UNPLATED
3/8-24 5 21 26
7/16-20 5 33 44
1/2-20 5 52 70
1/2-20 8 64 87
9/16-18 5 75 100
9/16-18 8 93 124
5/8-18 5 107 143
5/8-18 8 132 177
3/4-16 5 190 253
3/4-16 8 234 313
7/8-14 5 304 405
7/8-14 8 375 500
1-14 8 758 1,010
1-1/8-12 8 848 1,131
1-1/4-12
3/8-24 5 21 26
7/16-20 5 33 44
1/2-20 5 52 70
1/2-20 8 64 87
9/16-18 5 75 100
9/16-18 8 93 124
5/8-18 5 107 143
5/8-18 8 132 177
3/4-16 5 190 253
3/4-16 8 234 313
7/8-14 5 304 405
7/8-14 8 375 500
1-14 8 758 1,010
1-1/4-12
Thanks.
Thanks.
Well, I got the tap and die set out. The U-bolts are 9/16's 18 thread. Can't find any grade marking on them. Assume they are 5. Guess I'll go with 100 pounds.
How about the center bolt through the springs? Just tight?
Hey Mid-50's: be great if you'd include torque spec's with your hardware.
I will second that. I didn't do that and one day I was working on something under the truck and checked them. They were finger tight. Oh my! I had probably only put 100 miles on the truck at that time over a year or so.
Why.. Because they don't want to see it again, ever, and a lot of people aren't going to do any retorques. Check them at least three times first 100 and say 500 miles and then during periodic mileage maintenance. Put the suspension through its paces too, just zipping around town won't do.
Here's the link again
https://www.autoandtrucksprings.com/...lt_Torque.html
