Dashboard illumination
Old 01-21-2017, 09:44 AM
Andrewfriend's Avatar
Andrewfriend
Andrewfriend is offline
Hi, I drove my 1971 F100 for the first time in the dark the other day. The gauges did not light up, had no idea how fast I was going. I know it's an old truck but should they light up?
thanks. Andrew
Old 01-21-2017, 09:59 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
thanks. Andrew
Did ya try adjusting the dimmer function on the headlight switch?
Old 01-21-2017, 11:47 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
Yeah, the rheostat could be turned all the way down on the light switch or, it could have a bad spot in the windings and no continuity with the switch at a particular position within the range of being off to full brightness.
Old 01-23-2017, 02:03 PM
Andrewfriend
thanks I had no idea it had this function.
Old 01-23-2017, 02:05 PM
Andrewfriend
thanks for the answer I had no idea you could adjust the brightness on such an old truck.
Old 01-24-2017, 01:58 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
Yes, after the 69's Ford converted the headlights from LP gas to 12v DC. LOL
Old 01-24-2017, 06:38 AM
Classicdriver's Avatar
Classicdriver
Classicdriver is offline
Huh? My 1970 has the LP gas headlights, So I'm probably not the only one with a crank start on the front either then? Sweet
Old 01-24-2017, 07:19 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
good one Gary
Old 01-24-2017, 07:59 AM
maine71f100's Avatar
maine71f100
maine71f100 is offline
If it is not the rheostat I would also take the instrument cluster out it is fairly simple a few screws and a harness in the back. Just be careful with the harness as it is 40 plus years old and unplug. After removal you will see where the bulbs land and you can check each one. When this is out it is a good idea to just replace them.
HRTKD
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-31-2016 07:25 PM
rjmay
1999 to 2016 Super Duty
09-10-2006 07:11 PM
f1fordguy
06-02-2006 08:54 AM
Quick Reply: Dashboard illumination
