LOUD!! Rattling (mp3 file) from around bellhousing at 2,500+ rpm, not flex plate or torque convter
Hello everyone,
I posted a little while back due to the same issue and the popular openion was cracked flexplate (https://www.ford-trucks.com/forums/1...converter.html)
I have noise coming from the bell housing that gets louder and louder at higher rpms. Put a new flex plate and torque converter in but it did nothing to the issue.
Thinking it might be time to take it to the dealer because I am stumped!!
Audio file with noise is below!
Any ideas are welcome
See below for more details
I dropped the transmission to see a perfectly good flexplate, went ahead and replaced it anyway because I already had the part. Figured if it was not the flexplate it could have been the torque convert ( yes it was seated all the way but see below for potential issue) so I put a new one in. Got it all back together today and started it..... same noise....It is still coming from what I believe the bell housing but could be the very very back of the engine or the very very front of the transmission.
When seating the torque converter I got it in the first click and spent forever to get it to go in all the way. When it was only partially in it sounded fine spinning but when seated all the way there was a grinding noise when I spun it by hand but the noise would go away if I pushed up and supported the converter (the torque converter was fully behind the transmision case). When i mated it with the flex plate it did not make any noise when turning it over by hand.
I would love any ideas. At this point I think it might be a damaged transmission pump splines (due to the weird noise after second click of torque converter). It could be the very back of the engine making the noise though, did not want to remove the rear seal if there was no need because there is no leak.
Hello everyone,
Eli.Jp
12-11-2016 10:04 AM
FUJINAMI1293
13
09-05-2012 11:16 PM
dcdave
09-16-2008 08:07 AM
