16" Wheel & stick-on weights
I'm currently running 16" Ford steelies on my Excursion. I'm considering upgrading to a set of aftermarket aluminum, also 16". Any issues with stick on weights clearing the brake caliper with a 16" wheel? Clearance looks tight. I have the weights on the outside lip now but wouldn't want to do the same with a new set of wheels.
Yep. That's what I'm referring to. I have the hammer on clamp on the rim weights on the steel wheels. I will use stick on weights on the inside of the rim with the new wheels. I guess wheel offset should be considered too. Just wondering if anyone encountered the stick on weights rubbing the calipers with a 16" wheel.
55forder
06-02-2004 03:19 PM
