Mess in rear drums
make sure you cut the rear driveshaft in half if you havnt broke a u-joint my then.
I installed inferior seals on my truck, and its starting to leak.
just got the skf's on order
Ok, finally got time to work on this. Hub assembly is off. My instructions say to "carefully pry out the old seal." Anyone have a trick to doing this without messing up the bearing? It looks newish in there so I'm thinking the previous owner may have done this already but with normal factory seals. It's a Timken bearing under there and it looks pretty still
thoughts on seal removal with out harming bearing?
thanks
thanks
As far as seal removal, I watched a shop remove mine when they replaced it, and they just put a thin lever in there behind the seal and just worked around it. It came out pretty easily, but destroyed the seal in the process. Bearing was not harmed.
I'm just thinking about a F-150 I got, where the PO hadn't maintained the U-joints. Front U-joint disintegrated, jammed up. He floored it, which tore up the spider gears in the rear differential, and basically destroyed the entire rear end. The drive shaft wasn't harmed, surprisingly enough.
That being said, I definitely could see needing to remove the drive shaft as well, if you were turning a truck into a front wheel drive to get home.
Larger pry bar under the lip of the seal, make sure your prying against the hub on the opposite and not the bearing,and pop it out. You also want to be mindful the end of the pry bar doesn't score the machined surface inside the hub. Your not saving the seal so it doesn't need to come out straight, that's how I do most of them.
fisherman_chuck
01-04-2016 11:28 AM
cutthroatxxx
09-05-2014 03:10 PM
padd54
22
05-27-2005 01:43 AM
