Block Heater Alternatives for 6.9
Hey everyone,
Can't seem to find anything in the search engine, maybe I am not using the correct key words.
I have a 86 F350 with a 83 6.9 in it. Block heater is still there but I do not use it due to potential cracking of the block. What alternatives do fellow 6.9 owners use instead?
note: she starts right up at 0 degrees f weather after a few cycles of the glow plugs, but she sure sounds really angry that I had to wake her up.
thanks,
thanks,
They make radiator hose heaters that go in the lower radiator hose, and also magnetic oil pan heaters.
I'd probably go with the radiator hose heater, but the oil heaters work as well... just not as well, as the heat has to go through the oil pan first. And the oil isn't in a continuous galley like the water is.
Iam using a 200W Kats magnetic Oil Pan Heater each night, plus a 250W Heat lamp clamped to the frame, and pointed up towards the Starter/Pan/Block area. The light heats the block some what.
I believe in having warm oil to circulate through the engine a quickly as possible.
There are the electric heat pads that glue to the Pan to heat the oil also.
The lower radiator Hose is the next best thing to use if you are nervous of using the Block Heater as Macrobb mentioned.
I use the Heat lamp because....
1/2 or what ever # of my GP`s do not work, I have new ZD1`s to install, how ever I do not know what brand is in the engine now. For fear of them being Auto Lites, Iam not messing with them till summer, or the snow is over. Just don`t need one breaking off etc... and the threads are pretty rusty. Even with that, I stick a HF Heat gun down the intake for a few min. Once the GP Light kicks off she starts right up.
Charlie
Charlie
Received 3,108 Likes
on
on
reply
The "weak" blocks ran from 83 until 85 sometime in the midyear they were revised. I'll have to dig up the serial numbers. That being the case, the original motor and the replacement in my truck are both early 85 engines and neither failed from extensively using the block heater. To me it seems if the Hester could crack it then you're engine would when your loaded downtowing 15k+ with 210 degree engine temps..
Is this the info on the blocks?
Ford Truck Enthusiasts Forums - View Single Post - Do I have a Good Block?
Charlie
Charlie
Charlie
