Tips and tricks for steering box replacement?
Many praise the Redhead. Unfortunately my budget was unable to absorb the cost from other recent buck$zooka purchases. I went with an A-1 Cardone reman unit (I don't think you can get them new any more). I've been very happy with it and it was about 1/3 the price. When this one dies I will hopefully be able to get a Redhead.
Great point! I completely forgot to mention that. I used my seatbelt to hold the wheel in place so I didn't mess up the clockspring.
No. Never tested homemade concoctions... just formally sold goods from manufacturers, primarily obtained on sales calls as a comparison of "theirs" versus "ours". I would often swap the potential customer two cans of ours for one of theirs and then could test the "other guy's" stuff both at home and on our friction testing machines for later demonstrations.
The clockspring is a spring winding. It is the connection between all of the electronic stuff on the steering wheel (radio, cruise control, airbag sensor, etc.). If it winds too tight it breaks. If it's too loose then it could become misaligned...and breaks. Keeping the wheel straight so that you can line up the gearbox when it's straight will keep the clockspring aligned so that it doesn't potentially break or get damaged.
The reason you want to loop the seat belt through the steering wheel with the column UNlocked is so that you have the play necessary to get the splines to line up when reinstalling the steering shaft. UNlocked gives you movement you very much need. Seat belt keeps the wheel from going all exersist on you.
#28
You can get the box out with the pitman arm still on no problem. I realize now that I didn't mention it earlier but I had my gearbox in a vise when I pulled the arm off. Not enough leverage with it in the truck and I was afraid of what I might damage if something let go or I slipped (including me). I clamped it in a vise when I used the puller to get the arm off.
I had to let it sit overnight to get all of the ATF out of it before shipping it back as the core. If your gear isn't too shot you should be able to move it with your hand. Repeatedly going lock to lock will help expedite the fluid draining process.
#29
