depends how much you want to spend. add-a-leaf kits are relatively cheap but you can do a reverse shackle kit, such as the one from PMF, which will level the truck and make it ride ten times smoother also.
Do these trucks take a 1.5 inch or 2 inch kit to level the front with the rear?
Have you checked your front leaf/shackle bushings? Mine with new bushings and very sagged 300k+ springs was in the 1.5 range. I would suggest find some flat ground and measure at the rocker and see what your truck needs.
do the 2.5 kit and the truck will be level if rear is stock with the 4 inch block, i did the 3.5, rear is stock, and im 1 inch high in the front, good thing i did because my 35's rub if i turn to sharp.
