New wiper blades... Still suck !
I bent the wiper blades and that helped a bit but there still not as good as they could be lol. I read online that the culprit may be a worn out spring on the wiper arm. So i think my next plan of action is making an autozone run and buying a new $14 arm to see if that helps
When did you pick these up? When I upgraded to Bosch beam-style wipers, it would miss a large spot for a few days until the blade was "broken in"
That's the best way to describe it. It's like it needed to set for a while to form to the curvature of my windshield.
I would recommend them again, but give them a few days to "adjust"
I'm having the same problem with mine. I just bought this truck so not familiar yet how it reacts. The blades that were on it didn't hit the full windshield, just as you described. So I went out and replaced them with the Bosch brand only to find the problem slightly worse! Of course, the part that doesn't hit the windshield is directly in line with my sight. Hope you find a solution. Did the new wiper arm fix the problem?
FIXED IT GUYS !!! Went to autozone today and spend $16 on a new wiper arm. Grabbed a hose sprayed the windshield and turned the wipers on and bam. Problem solved. It appears the springs pushing the arm against the windshield were just plain shot.
johnboggs21
17
06-06-2010 02:21 PM
66worktruck
01-22-2001 12:45 PM
