no air through dash vents, defrost only
Old 01-08-2017, 01:12 PM
hipo_p51's Avatar
hipo_p51
hipo_p51 is offline
This has been on going for the past year. the blend works fine. fan speed works correctly. the selection **** for ac, max ac, etc will only allow air through defrost vents.
vacuum leak?
1998 4.6 auto super cab
Old 01-08-2017, 05:23 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
See HVAC FAQs, link is in signature below.
Old 01-08-2017, 05:37 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
all the vacuum cylinders that direct air thru the ducts are controlled by vacuum from the motor... vacuum line runs to your selector switch, then to each cylinder thru the selector valve... when you loose vacuum all the cylinders close and the air goes to defrost..... You have a leak on the hose at the firewall, behind the selector valve, or inside the selector valve itself ...... check hoses first.... have seen cracks in the TEE or hose at the firewall, right side of motor at firewall in front of glove box.
Old 01-09-2017, 10:22 AM
hipo_p51's Avatar
hipo_p51
hipo_p51 is offline
Thanks for the help.
Old 01-21-2017, 04:25 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
Very common problem. I have had the same issue.
rvarc
1978 - 1996 Big Bronco
08-03-2018 09:17 PM
1999-F150
1997 - 2003 F150
07-10-2017 08:42 PM
longmire56
1997 - 2003 F150
10-30-2015 10:06 PM
02GrayPowerStroke
1997 - 2003 F150
07-28-2015 07:37 PM
Mr Dave73
1997 - 2003 F150
11-27-2010 01:41 PM
Quick Reply: no air through dash vents, defrost only
