Still smell fuel
Old 01-07-2017, 08:08 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Still smell fuel
I have been smelling fuel on and off for the last few weeks. I thought it was the fuel bowl drain valve so I ordered the kit for the whole fuel bowl from diesel o-rings. I did the rebuild this morning and I don't see any visual leaks. Still smell a strong odor of diesel though. The lower engine cradle is all wet and the valley is still a little wet too. Could I still have a leak and if so where to look? Could it be just wet still from draining the fuel bowl and needs time to go away?
Old 01-07-2017, 09:19 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
If it's warm enough where you're at spray some Simple Green or Purple Power on it & wash it with a water hose, if not it will take what seems like forever for the fuel to dry up.
Old 01-07-2017, 09:32 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
I have that lurk of the whiff too. No puddling and valley is dry.
Hawking this.. I did the scrubarama with simp and I can't find it.
Denny
Old 01-07-2017, 09:33 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Yea it's no where near warm enough. Ambient temp right now is about 15 for the high. Hopefully that's all it is, left over fuel. Thanks for the reply
Old 01-07-2017, 09:37 PM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Your pass side fuel line could be leaking.There is a clamp on the valve cover that wears a hole in the line.When mine was leaking I replaced the line and got rid of the clamp.
Old 01-07-2017, 09:48 PM
DieselDenny
on it! I'll report.
Denny
Old 01-08-2017, 01:31 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
I use Brake Kleen to clean the valley. No waster mess and quicker.
Old 01-08-2017, 02:42 PM
cj45lc's Avatar
cj45lc
cj45lc is offline
Good idea
Old 01-08-2017, 03:11 PM
F250_'s Avatar
F250_
F250_ is offline
Those little divets in the valley can hold lots of Brakleen.
Old 01-08-2017, 03:49 PM
aklim's Avatar
aklim
aklim is offline
Brake Kleen, air blowing, repeat a couple of times. That or engine degreaser and flush generously. Dump twice the strength of recommended dye in the fuel and drive. Watch with blacklight.
Old 01-08-2017, 05:25 PM
countrycar's Avatar
countrycar
countrycar is offline
Check that your fuel filter lid is tight. I had a leak I couldn't find on my Excursion, and it turned to be the filter lid wasn't tightened properly.
Old 01-08-2017, 05:28 PM
aklim's Avatar
aklim
aklim is offline
Good point. Check out if the gasket is in the right direction. Ask me how I know.
Old 01-08-2017, 09:23 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Well put about 75 miles on it today and the fuel smell is not as noticeable. Maybe its just needing to give it a day or two. Ill keep you guys posted.
Old 01-08-2017, 09:46 PM
aklim's Avatar
aklim
aklim is offline
Good luck. I'd still wash it to know
Old 01-09-2017, 08:51 AM
F250_'s Avatar
F250_
F250_ is offline
Could it simply be residual fuel from the previous leak which is resting in the hollows in the valley? They don't drain completely by themselves.
Quick Reply: Still smell fuel
