Frankenstein 1965 f100 4x4
i have a 1965 f100 4x4 that was originally made as a 2wd but it was later converted to 4x4 it has a dana 24 and a dana 44 as well as a ford 9 inch, i guess the drive line is a f250 drive line because it has a 8 bolt pattern and 16 inch rims but it also has a 300 inline 6, it also has a 4 speed. im a young guy that has alot of questions so i'll be needing some help
i paid $1200 cad worth it?
Did the dana 60 have 8 bolt?
Could be. You can ID your own rear axle or take a pic and post it.
The 9 inch should have bolts/nuts on the front side only where the driveshaft comes in. The back side is smooth with no access cover.
Ford Rear Axle Assembly Identification - Page 01 - FORDification.com
The Dana 60 has an access cover that is on the backside and can be removed without removing the driveshaft or usually anything else.
Axle Builder | Dana 60 Identification (BOM Lookup)
Or it could be a 5 lug 9 inch with adapters at the wheels to run the 8 lug rims. There's a few possibilities.
on
1 Post
It's interesting that you have a Standard Cab truck, with Tu-Tone Paint, according to the Warranty Plate decode by NumberDummy. I can't think that this is too common, I could be wrong, hopefully others will chime in.
Do you have the white metal with round speedo (Standard Cab) or the silver/chrome like plastic with sweep speedo (Custom Cab) ?
Do you have a horn button or a horn ring (with spokes) in the steering wheel?
i have a button that is the best pic i have on me rn.
