bad caliper?
2000 f 150 4.2 v6 232,000 miles
So I just replaced drivers side brake hose and the caliper still won't bleed.
Does that mean a stuck piston will restrict the flow. .....
?? Can you maybe tell me, what it is that all my brake lines go to; it's located below the master cylinder ??
Thanks
Thanks
The piston can't get in the way of fluid coming out of the bleeder.
Are you saying that with the bleeder open and the master cylinder full of fluid, pumping on the brakes doesn't make any fluid pour out of that bleeder? If that is really the case (and it would be quite rare) I would work backwards, removing pieces of the brake line until you find where the blockage is.
Alright I think maybe I should start from the beginning, going crazy here. I was experiencing violent shakes in the front end when I would apply the brakes then a couple days later I blew a brake line leaving work. I then proceeded to drive home (30 miles) nice n slow. The blown brake line was back by the gas tank along the frame. I recently fixed the line then started the bleeding. I'm wondering if I should have done something different before bleeding. Is there a chance that I could have caused damage somewhere. Could I have possibly caused some kind of vapor lock within the system. I don't know.
No such thing as vapor lock in a brake system and the pcm isn't related to the system at all.
Honestly it sounds like the ABS pump isn't letting the fluid through. I really don't know that much about the ABS pumps on these trucks, to be honest. Maybe someone else will know something about it... have you also tried searching or posting in the forum specific to the truck?
bigtexan99
10-24-2014 01:14 PM
