F350 rear leaf spring shackle bolt.
2001 F350, 4x4, 7.3..
I am replacing the leaf springs on my truck and started with the rear drivers side. Everything went smoothly until I tried removing the leaf spring shackle bolt. The one closest to the rear with that rubber bushing around the bolt. The nut is off and I can turn the bolt but I can not remove it. I dropped my hitch so I could bang it with a sledge hammer. Then I bought a air compressor and air hammer. Bolt still wont back out. but it does turn.
So I figured I would cut both sides. there is enough room between shackle and brace to get a blade in. So how do the experts get the bolt out?
Should I cut it or is there another way? Guess I will need good sawsall blades for that hard steel.
Thanks Joey
Thanks Joey
I think you guys are right. I should hang on it some more. The frame is still in my way a little.
So I will duck tape my air hammer punch to it. That will extend my impact point past the frame. I could even use a bigger sledge hammer if I did that. Anything has to be better then cutting it with a sawsall. I will update you guys tomorrow. I have always gotten great help from. This forum.
So I cut it out. Cutting it out was very fast. I cut the threaded side of the bolt on the outside of shackle and in between shackle and bracket on other side. Only took a few minutes. I bought those expense sawsall blade, $15 each. Cut through that bolt no problem. Even with the shackle out the remaining bolt is still stuck inside the shackle. Don't know what is holding it in but it's in there forever.
There is a metal sleeve inside the bushing that basically rust welds itself to the bolt making it almost impossible to get it out. When the bolt is turning its actually turning the sleeve with it.
Twitchyleprechaun
05-14-2015 08:40 PM
traxx808
02-26-2012 04:18 PM
websthes
08-05-2004 01:42 PM
