2016 F250: recommendations on wheel liners, arches, and mud flaps?
I have a 2016 F250 CCSB 4x4 SRW XLT. At 2500 miles I already have some small rock chips behind the wheel wells (a problem I never had with our 2006 F150 or 2010 E350). So I want to add rear wheel well liners, arch guards, and mudflaps. Any recommendations? My primary consideration is ease of installation.
Took about 15 minutes. Stupid simple. One piece of advice for the Husky liners, it requires 2 holes to be drilled in the bed sheet metal. The instructions say to drill both these holes then put in the screws. I'd recommend drilling one hole, then screw it in, then drill the other hole. You won't have to worry about trying to line up your screw holes because the liner flexes as you hold it up. Since it's cold out, I also sat the liners in front of the fire for a few hours to get them pliable.
Robbgt
2009 - 2014 F150
04-22-2013 06:46 AM
