Getting it started
Getting it started
This evening I tried to start my rebuilt 400 for the 1st time - didn't want to fire. Seemed to light off a couple of times, but would never catch. I have the initial timing set at 12 degrees BTDC & verified I'm getting a spark. I cranked the engine with the throttle wide open & nothing; pulled a spark plug & it's dry, so I'm thinking it's a fuel issue, right? Fuel level in the primary bowl is just above the top of the sight glass, idle mixture screws are 1.5 turns out, fuel pressure is running 3-4 psi while cranking. I've got a melling cam .486INT/.512EXH, set straight up, TMeyer pistons, and Holley 670 street avenger. Any ideas would be greatly appreciated!!!
To ensure it isn't a fuel issue you could see if the accelerator pump squirts gas into the carb when you hit the throttle. If so, then try to start it with the choke on and throttle closed since a dry plug suggests it isn't flooded.
If that doesn't work, check the plug wiring. Perhaps the rotor isn't pointing at #1 when it hits TDC.
Good advice...the accelerator pump will be your first clue if fuel is actually getting where it needs to be.
Second on the plug wires. In fact I've seen an instance where a cap was wired clockwise instead of counter-clockwise from #1. Another common problem is stabbing the distributor 180 degrees off - TDC on the exhaust stroke instead of compression.
1968f100ranger
10-14-2009 07:20 AM
13MWZ
03-05-2006 01:44 PM
gearshift101
11-06-2004 09:01 AM
kochy54
02-12-2002 07:15 PM
