0W40 Oil in 5.4
0W40 Oil in 5.4
As engine oils are kind of expensive here in Europe and 5W20 is not readily available I was wondering if I could use the 6 Liters of Shell Helix Ultra 0W40 fully synthetic oil In my truck I still got laying around in my garage from my other vehicle.
I used to have a synthetic Liqui Moly 5W40 before a 5W20 (Addinol brand) in my engine, both without any problems and reasonable oil consumption. No sluggishness or abnormal noises with both oils.
Any experience with the 0W40 weight oil?
it tends to be chilly in northern Germany so I figured the "thin" viscosity would be great as well as the "heavier" weight when hot for the Autobahn use (yes, I ran my van 100MPH+ for 50 straight miles - got a trans cooler and both ATF and coolant temperatures were just fine).
Any experience with 0W40 fully synthetic?
UOAs?
P.S.: I run the van on Propane/Butane dunno if that's important
UOAs?
There's a Stag300 with 2 vaporizers and a 108ltr Irene spare tire tank mounted in the van, works as it should and only needed the regular filter change in the last 120k km. I had a BRC plug&drive system in my '00 RAM 2500 with the 5.9 and liked that a bit more, just for the fact that you mix a bit of gasoline to the LPG under high load situations (high rpm/high speed or heavy towing) to get the exhaust valve temps down a bit.
Don't mix up lubes too much
Next spring I will definitely upgrade my headlights, paint my bumpers and remove dents as well as get all the old putty out of the drip rails and re-seal them. Thought of using marine grade Zinc Epoxy primer followed by white Sikaflex 521. That should keep out rust forever. I'll keep you updated on my progress. The van has just 40k miles on it.
I don't think you'll have any problems with 0w40 oil. It's going to be thinner when cold than the 5w20, so you should get adequate flow to the heads on cold startup. It will be thicker than necessary when hot, but other than a minute reduction in fuel economy I don't think the engine is gonna care.
great news I won't have to dump the oil in the salad
On my last two oil changes I've used Mobil1 0W-40. It is what I use on my wife's 335i and I though it will add some extra protection last summer as we went on a road trip through Death Valley.
Originally these engines were supposed to use 5W30. With 0W40 you may hurt your mileage (or L/100km) but may offer extra protection under heavy load (autobahn).
Why so thin? sure your engine is younger than mine, but if 5w30 is recommended...
I was running 10w40 for about 20tKM, until a friend of mine told me about Problems with camshafts caused by to thick oil. I've Chosen the 10W40 cause ist cheap....
Now found 20L 5w30 from Eurolube on eBay (.de) for only 80€ and Changed immidiatly.
